Hmmm...I found that when you practice it enough, you stop thinking about heel-toe downshifting and just do it as automatic as you would up-shift. When we all first started learning the clutch, it was ugly, but the rewards are far better than ignoring it and getting an automatic. Don't do that!
You definitely do not want to let that 1,500 rpm jump happen too early...nice way to over-rev the engine. That quick bark of the rear tires can become a horrific KA-BOOM if you just pulled your engine well past redline.
You might consider whether or not you want to change brake pads more often or the clutch more often. Your call.
I just got back from the Autobahn CC, and one of the major objectives was to test my braking. I was getting some truly horrific rear-end instability the last two times out that was making it impossible to really drive the car hard. Long story short, the culprit was a bad alignment. The rear of the car was not centered (though not far off, at only 1/8" off center), and the front was all jacked up. HUGE THANKS to SoundGuyDave for teaching me to string the car (it's actually fun).
The car is now stopping extremely well (and turn-in has improved, thanks to a more suitable alignment), but I still get a bit more brake dive than I'd like. I chalk most of that up to r-comps and springs that are really not up to the task.
FWIW, I'm running a Stoptech 14" BBK up front with XP12 pads and stock calipers/rotors out back with XP10 pads. I'm going to change my rear LCA angle, and then see if I can get some temps taken of the rotors. Some folks have found great success with running the same pads on all 4 corners (I used to w/stock front calipers), so if temps seem to warrant it I may try that as well.
Best,
-j
