Brembo Help!
Roadracer350
Tulsa OK
Ok I know this is proabbly not the right forum but we are all roadracers and someone may have already done this. I picked my brembos up from the powder coating today and they have split the halves. Can I just put them back together? If so does anyone know what the torque value is on the 4 bolts? Or am I just FUBAR? :omfg:
SoundGuyDave
This Space For Rent
Get the tech from Brembo. You should NOT be FUBAR, but make sure the powdercoat isn't on the mating surfaces, piston bores, or any of the hydraulic passages. Any further word on the chassis?????
Fuerte
I know on other brembos, a friend has a 240 with z32 calipers, that there are oring between the halfs and is super hard to find.
Sent from my SCH-I535 using Tapatalk 2
Fuerte
Nope no o-rings or any provisions for them.
Really? I was super scared to spilt mine for power coating now not at all. So as long as the matting surface is flat there is no problem splitting them and putting them back together?
Roadracer350
Tulsa OK
I don't know. As far as I can see their is nothing their. I am calling Brembo North America as soon as I get to work this morning. I will let you guys know what they say.
kevinatfms
EX-ford tech(6 years)
MD
if I can find it have the breakdown diagram for the GT500 calipers. ill see if I can find it and let you know. its been quite a while since I used most of this FRPP tech stuff I have...
Westland, MI
No O-rings between the two body halves on that caliper. Your transfer tube carries all the fluid. Clean it and bolt it back together.
Roadracer350
Tulsa OK
Amy at Miller Motorsport Park to the rescue!!!! Caliper Bolts are torqued to 65FT LBS. Even Brembo North America couldnt tell me. They said they would have to call overseas and it would be the end of the week. Amy had me an answer in 3 min! God i love that woman!! :allhail:
Roadracer350
Tulsa OK
Yep just make sure to torque the calipers to 65ftlbs and your good to go!!! :clap:
Roadracer350
Tulsa OK
You know what size thorx bit is used to remove the bolts?
Not sure on the Torx socket yet. I know a 11MM socket fits but not sure about the Torx yet. I will take one of the bolts to work tomorrow and find out
