probercr93
Banned
First off I have a set of front cross drilled rotors from brembo. These are brand new and never been used. I paid right at $400 with shipping. I'm not planning on using them on my car anymore, so I'd like to get $300 plus shipping.
Features
The world-renowned stopping power of Brembo can be had without replacing your vehicle's stock brake system. Brembo Sport Cross-Drilled Rotors directly replace marginal factory parts with high-quality counterparts that outperform all others.
Brembo Sport Cross-Drilled Rotors utilize choice high-carbon cast iron for their disc. This guarantees top performance in both street cruising and high-speed motoring, and reduces braking noise.
With their cross-drilled design, Brembo Sport Rotors provide more bite when it counts. The holes provide a clear path for heat and moisture to escape, helping Brembo Sport Rotors perform in any element.
Brembo Sport Rotors work directly with stock brake components, installing fast and fitting superbly. Brembo Sport Rotors even fit with the stock wheels and tires, making this set an easy upgrade. Indeed, world-class stopping power has never been more accessible than with premium Brembo Sport Cross-Drilled Rotors. 2-year warranty.
Next I have a Turbosmart Eboost2 electronic boost controller. This can also be used as a nitrous window switch, among many other things. It retails for $540 plus shipping. I'm not sure if I really want to sell it, but make me a good enough offer and it's yours. It is brand new in the box and never been used.
SOLD!!!! I also have this amazing comp turbo's turbo blanket that I'd LOVE to use, but can't because I just don't have enough room between the turbo and the motor. So I have absolutely no use for it. They sell for $150, I obviously didn't pay that because I'm a dealer, so I'll sell it at a small loss @ $75. This is for a T4 housing. and is brand new.SOLD!!
This is a Spec stage 3+ clutch friction disc. I went to a tr6060 and could no longer use this 10 spline disc so it has maybe 4,000 miles on it. Spec sells them for $260 plus shipping new, I'll take $125 plus shipping.
Stock flywheel make offer...
Stock Driveshaft make offer...
Features
- Brembo Sport Cross-Drilled Rotors are widely regarded as the world's finest factory-style replacement discs
- Forged from high-carbon cast iron that guarantees top performance in any driving situation
- These Brembo Sport Rotors utilize a cross-drilled design that evacuates heat and refreshes brake pad surfaces for better bite
- Drilled surface also wicks water away from the rotor surface, noticeably improving brake response in wet weather conditions
- Brembo Cross-Drilled Sport Rotors are directionally vented for maximum grip and centrifugal evacuation of heat gasses
- Made to directly replace your stock rotors without the need for additional parts, modification or larger wheels
- Brembo Sport Cross-Drilled Rotors work with the stock calipers and other brake components including ABS parts
- Manufactured entirely in Brembo Brake facilities across the world
- Brembo Sport Cross-Drilled Rotors have earned prestigious European TUV certification for quality
- Reduces braking sound
- Your Brembo Sport Drilled Rotors are backed by a 2-year warranty
