I have a built and Mommoth Blown (18#'s) 3V with a Livernois Stroker Assembly rated to 900HP. The car has a smoking issue at 3000RPM, but not at startup or at WOT. Pulled the plugs and found oil on one of them, through the use of a bore cope, found that one of the ring lands on the Mahle Pistons is broken.
Question, for a High Horsepower/Boosted motor (600RWHP+):
1. What are you guys using for pistons (JE, CP, Diamonds)?
2. How much over size can you go on a 4.6 (.010'', .020'' )?
3. Any recommendations on who to purchase through?
