Built Long Block 3v
KillrStang
Texas Grown
Bryan, Texas
Whats up guys i have a built long block out of my 09 3v. This motor is a fresh rebuild with a little over a 1000 miles on the clock. I parted out the majority of the car being i had a daughter and haven't really touched the car in about 2 years. My loss is your Gain. i will be 100% upfront i melted a piston about 3 years ago, faulty tune(psi motorsport). So this motor is bored .020 over. When i did the rebuild i went back with all new pistons, rings, bearing, and side/main cap bolts
The Goods :happythumb:
Short Block
JDM 302 E (aluminum)
2618 manley pistons
mahle/saleen H beam rods
Kellogg 3.850 Crank 8 bolt
Total seal rings (cant recall ring gap but it was huge for big boost)
Mogul Bearing
ARP rod bolts
ARP head Studs
Tss Billet oil pump gears
ATI balancer
Canton low profile pan (8 Quart?)
Heads
Hand ported and polished
5 Angle valve job
Ferrea Valves
Titanium Retainers
Comp Springs (26113)
V10 Vct Blockoff plate
side note: there are 2 hela coils in the spark plug gally
I have Invoices for everything and a can get flow numbers on the heads if requested
$6000 shipped From Bryan Tx
I can have it looked over by a local shop for a $500 dollar deposit (covers cost of inspection) If something doesn't check out i will refund the $500 dollar deposit.
