Bulletproof built rear end complete
Selling my drag stuff. S197 8.8 rear, tubes welded and braced, heavily braced, swaybar relocation brackets, lower control arm relocation brackets, spherical upper mount bearing, Shelby adjustable spherical bearing lower control arms, ford 3.73 gear, Strange 35 spline spool, Strange 35 spline race axles, Strange C-clip eliminators(no leaks), Moser extended wheel studs, Strange single adjustable shocks. Gear makes a little noise, but is fine for track use. It would cost you $2500 to build your rear end like this. I will take $1300 for the entire set up. Located in Yadkinville NC 27055. I don't mind loading it on a pallet if you wanted to have it picked up at my business for freight shipment, buyer arranges shipping. Killer deal for someone making big power
Probably 2k street miles at most. I had a street rear end I swapped in for street cruising. This was used mostly at track. And probably around 30-40 passes
