Burnt rubber removal
reddsled
Cherry Hill NJ
Been going to the the track more often so I got some new slicks. Now the rubber and track muck is all over my 1/4 panels any tips on removal? Next time I will be more prepared and leave a thick coat of wax on the area before heading down but for now I am in a sticky situation (pun intended)
mikeyfitz
Houston, TX
Put painters tape on your quarter panel.
reddsled
Cherry Hill NJ
Yea but how do I get the rubber thats on there now off? WD-40? Gas? Denatured alcohol? Mineral spirits?
Brezick
Yinzer
Bug & Tar Remover, WD 40, Mothers R3 Rubber Remover......alot of shop towels and patience. Also, so things you can spray on before going and it will help wipe off after.
I just went through this too many times and finally ordered some splash guards to hopefully deflect some of the rubber.
fdjizm
Drag Queen
NY/NJ
WD-40 all day, gets it right off.
I use painters tape when I go out, also I've heard of guys spraying pam on their panels so they can just wipe the rubber right off. And also smells like buttery goodness.
Seer
Burnout guard is a good prevention spray.
mr. anderson
Moore, OK
NEVER USE PAM! that stuff turns the rubber into a goopey goo if you don't wash it off right after the track event.
fdjizm
Drag Queen
NY/NJ
^the point is washing it away after the track event lol.
reddsled
Cherry Hill NJ
I work at a sign shop so I will try and get some low tack. Then spray it red and put that on the quarter panels for the next trip.
itsslow
Try heating it up a little with a heat gun, don't overdo it though, you'll burn your paint. I usually wipe off the rubber with my hand after each pass and wash my hands afterward, did it more than 30 times
808muscle
Maui
I used wd40 for 3 years now but I am over all that cleaning. I just bought a nice big roll of painters tape.
reddsled
Cherry Hill NJ
Using WD-40 while drinking beer works. At least thats the spin i put on it. Now on the search for red painters tape.
