justinS197
Go low or go home!!!
Well it was a sucky,rainy and wet day just perfect for cleaning up and waxing! I still need some advice on the wheels and tires heres some pics at what i done!
BEFORE
1 notice the hood is just primed and ruff!!
AFTER
1 And now the hood looks painted and glossy but its still primer!!I also buffed the lights, and all thats needed is to be sanded a bit and clear coated!
5 I sanded the mirrors but heres the side i haven't done its real ruff and almost felt like velvet any ways heres before..
6 After I wet sanded it also ready for another clear coat!
7 Now tires and rims- whats the best thing to use to get this oxidation look off the rims? Im guessing some type of rim polish and a really good buff job?!?!
8
9
10
11 Im guessing that there is no way to fix these dry rot cracks that looks like tire stretch marks??
Heres what makes it worth it!!! 351 windsor!!!!!
BEFORE
AFTER
8
9
10
As far as the wheels go, you need to use a really strong wheel cleaner with acid in it. The acid will remove all the oxidation and rust. It will obviously remove all the polish as well, but that is not a problem because you need to polish them again anyhow. Now get some metal polish and get to work! Also, I have some extra screws for the center caps if you want them since yours are all rusted. With a little bit of time and elbow grease those wheels will look as good as new.
