Cabin Filter replacement
ixtlan
Hooper, Utah
2005 Mustang Cabin Filter Replacement
(Also applies to other vehicles as most are similar)
Ok I decided to replace my Cabin Filter.
Here it is:
Open Hood and remove two really cheap plastic screws (they are actually clips) that hold down the plastic cowl section on the passenger side.
No need to remove the cowl or wiper just lift the cowl section a bit.
Here you can see the filter in place
Just tip the filter top forward and unlock and remove.
Here you see the filter removed.
Just
Filter removed from another view.
These are the Old and New Filters.
Filter is in a plastic frame Here shown with removed and new filter installed.
The thing was Filthy with only 8000 mi.
Just replace and re-install.
Took about 10 minutes.
Cost of filter was $20 from Ford.
Too Easy, and now you know.
V
VSOP
Guest
Sweet.. I was thinking of doing this since I know mine is probably nasty..
I wonder if there are any other sources for the filter other then ford.. I might have to look into this..
94tbird
4R70W FTMFW
so thats where it is. i got one sitting here but havent gotten around to it yet. good deal. Thanks
ixtlan
Hooper, Utah
When I did the writeup there were none. Fram did have a P/N but it wasn't available at the time.
KartRacer39
Cabin Filter.... Awww Crap I have 53,000 miles and I expect Mine is trashed. Nice write-up !!! I guess I'll get up the energy to change it now.
ixtlan
Hooper, Utah
does K&N make one to fit?:kill:
Not according to thier website.
But why would you want tp pay for a K&N?
Got to be a bunch more money for the brand name...
P/N's
Purolator
C25572
Bosch
P3756
Motorcraft
FP53
WIX
[FONT=Arial, Arial, Helvetica]24687
[/FONT]
Dread53
Woodland Park, CO - 9000 ft!
A little heads up for anyone with a CDC style hood strut - unless you remove the fender bracket for the strut on that side it is a real PITA to get the cover off and on. I did it without removing the bracket and I won't try that again.
Thanks for the write up, because I didn't know I had one either!
Hitman
Banned
Tennessee
P/N's
Purolator C25572
Bosch P3756
Motorcraft FP53
WIX [FONT=Arial, Arial, Helvetica]24687[/FONT]
I was kidding and implying that anyone that would want a K&N cabin filter should shoot themselves in the head.
