Can I reset TPS
Hollowdweller
Can I totally reset the throttle position sensor settings on my 2006? Just installed a new TPS fighting a “reving while driving issue” and I’d like to totally reset the system. The readings off (1.17 vs 1.2) and I don’t want to go thru all the BBK bs to dial it exact. I think I damaged the set screw on the adjustment screw so I added some Loctite to the threads to secure it. Don’t really want to break into all that. Plan to rethread the set screw once I see if the sensor was the issue. Everything’s been fine but now the new sensor has a different reading. Can I just reset the system for the new readings?
whitmanink
denver pa
the only way to "reset" the system is to set the tps at the stock voltage ,, and rest the cam data and unplug the battery to reset.. and go from there .
that pending you didnt mess up the tps
