Cant figure it out....
Lee's05GT
Formally Qksixx
Tacoma,Washington
So I keep hearing ALOT of movement when im driving the car coming from the driver side front. I wasnt experiencing any problems until i put the d-specs in. I can only hear it like when I hit a pretty big bump in the road like it seems to do it when that side is taking the full load and it seems like its moving around. But Ive checked it like 2-3 times and everything is tightend down and looks fine, even had it looked at and they said it was fine. But i know its not, it should be acting like that. The only thing that is coming to my mind is if that shock is gone.....but im not sure.
19COBRA93
Ford Racing
Clinton, Ut
Check and make sure the the sway bar end links are tight. I've had one come loose on my car after doing some GT500 takeoff parts, and we get them in to the dealership all the time with stock end links that have come loose.
19COBRA93
Ford Racing
Clinton, Ut
im not to familiar with sway bars and what to look for. What do you mean by end links?
It's the link that attaches the sway bar to the strut. The link has a stud that goes through a mounting point on the strut then a nut goes on the other side.
usafimj
I had that same problem. My bro-in-law checked it out when I was deployed and he said the swar bar was loose. They tightened it up and it went away. Now I have to do my passenger side because I'm getting the same thing.
Lee's05GT
Formally Qksixx
Tacoma,Washington
good to know. I guess ill check both sides then! I hope thats the problem!
