Car bucking yesterday....
2014_GT
Bowtie Bitch-Slapper
Lake Jackson, TX
We have some shitty alt's. Seems to be a common problem.
Actually, it's a common problem with the mod motors, not just on Stangs. I think it's due to the location and the amount of heat their exposed to. Every Ford vehicle I've owned with a mod in it, e.g. F-150's, etc., I had to replace the alternator. Now, I haven't had any issues with my Mustang so I'm new to this particular fault code... but it makes sense now that it's explained.
RyNo
Philipsurg, PA
Did the alternator fix your bucking problem? Mine is doing the same thing right now but everyday. At lower rpm with steady throttle input. definitly in 5th gear crusing on the hiway, you can hear a light pop or backfire with steady throttle...
Redfireshaker06
Central Florida
They ran the test this morning that the TSB suggest. And it failed. So I'm 99% sure that was my problem since I was throwing the code that the TSB mentioned. I probably won't know till tomorrow or Friday since I have some other stuff getting done also.
RyNo
Philipsurg, PA
you said it was the p3040? cam pos sensor? im getting that also. I have a fuel press gauge and the car starts kickin around the pressures go crazy!
3vs197
My car is having the same bucking problem but no codes. Already repalced the alternator 1.5 years ago but I wonder if thats my problem again?
RyNo
Philipsurg, PA
I cant wait to hear what he comes up with from the shop, its really sucking trying to mosey around town and it looks like my car is trying to bunny hop. I checked on my csps code and that turned out to be a loose connection on the sensor. the check eng light went out but still buckin...My ole man said its suppost to do that its a Mustang.. smartass:nk:
mac10chap
The bouncy tits guy...
houston, tx
What do you have done to your car? I noticed you said that you bought new plugs. Did you gap them properly? I know when I got my motor swapped out, I had my shop replace the plugs. They forgot to gap them and the car bucked and ran like shit. They realized what they had done, gapped them, and it ran perfect.
If not that, they my money is on the alternator. When it goes out, it throws codes for all kinds of random shit that "could" be wrong. 99/100 times, it is the alternator.
RyNo
Philipsurg, PA
It just seems weird man. It seems like a fuel problem. I can watch dvds all day with the car off & fires right up. Nothing else weird is going on just the bucking as far as mine goes. waiting to see what sir finds out from the shop
RyNo
Philipsurg, PA
So.. I tested my alt with a multi meter today, checks out fine 14.3dcv.. Do you think it could need the ecu re flashed? Im going to get the alt load tested just to see but i dont think that is my problem.. any ideas??
