thunderstang
Alright guys due to an unbalanced one piece DS I now have a leaky pinion seal. I'm pulling the DS to have it rebalanced and changing the pinion seal. At the same time I'm going to pull the whole rearend out to weld the axle tubes.
My question is with the rearend sitting on jack stands and the brake calipers removed how do you guys keep the pinion and gears from turning while torqueing the pinion nut?
The reason for pulling the brakes is so I don't have to bleed them and to measure the rotating pressure with an inlb Tq wrench per the R/R directions so I don't over tighten on the crush sleeve.
