clogged cats question
cfr865
N. Illinois
I just had a built 302 short block installed, however it wouldn't make power, my tuner said the cats were bad, I ordered some high flow cats to replace these. Now I'm wondering if I should have went with the off- road pipe. The reason I didn't is becauase of the extra noise. Will these high flows be okay or will they burn up also.
tmcolegr
It's All About the Build
Central, FL
That depends:
Can you run an off road pipe in Illinois
Do you know why your existing cats failed? If you don't fix that problem chances are the new cats won't last either.
cfr865
N. Illinois
That depends:
Where I live in Il. I can run it with the off road pipe. I was looking at Brenspeeds site and they offer Metallic cats that fit into the off road pipe that are suppose to with stand the heat of f/i. I don't know for sure why the cats failed , I don't think its un-common with f/i for it to happen, but I'm not sure, I was wondering how many have cats with higher hp with f/i. I'm planning on around 530-550 whp.
tmcolegr
Central, FL
If your state doesn't require cats, why not stick with an off road x or h pipe and mufflers that suit your taste and completely eliminate the possibility of a cat failure.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Amen, brotha... amen. Way too many engines lost due to cat failure.
tmcolegr
Central, FL
I feel sorry for all you poor bastards that live in states that have state inspections and require cats.
God Bless Florida!!
sc281
5.3 big bore block
SLC, Utah
My American Racing high flows lasted less than 10,000 miles before being plugged. I had to replace them to pass emissions!
NastyStang113
Made in U.S.A.
Central Florida
Agreed, I don't like the idea of running them. It's one less thing to worry about in my opinion. Even if I lived in a State that required them I'd probably switch my mid pipe for inspection.
lostsoul
2014 vett or 2015 stang..
Gay Area
buy another stock h-pipe and hollow it out. it's an easy 15-20lbs weight savings too =-)
gmantheman
Escondido, CA
I better Knock. No! make that pound on wood that my cats don't clog. Especially since my cats are ceramic substrate. I ran O/R before, but I was always worried about the smell when driving near cops.
lostsoul
Gay Area
the gas smell is yor cR telling you to add more timing and lean her out ;-/. Haha
SteveP
Modular Specialist
Boynton Beach, FL
God Bless Florida!!
thank God tuners can shut off your check engine light so when the inspector plugs in his scanner. no codes.
