hazzardoustoysjr
- Joined
- Sep 24, 2013
- Posts
- 104
- Reaction score
- 1
long story short my single turbo 3v floated the valves on dyno around 5500 rpms and I was told I need to replace the valve springs. something I wish wasn't overlooked when I had the motor out but either way. Many mistakes were made along the way, listened to bad information and built a low compression motor, had to increase boost to try and make the original power number and didn't replace springs etc. The car made 530whp at 16psi but power fell off and boost went up at 5500 rpms. I was told by the guy who tunes my car he believes it floated the valves and turned to boost back down until I could fix the issue. He has a very reputable shop for mustangs local to me in Delaware.
I've came to the conclusion the are 3 ways to do this.
1 remove timing cover and pull cams to do the springs
2 remove cams and wedge the timing chains
3 replace springs without removing cams
my question is why do so many people opt to do it with the cams out?
it seems like extra work but maybe it makes it easier.
I would like input from anyone who has done this job, thank you so much
the car has a built shortblock and 6060
