coolant hose replacement for paxton
gavin.biegler
is there a cross reference part number for the coolant line that goes from the driver's side coolant crossover to the thermostat? paxton/vortech part number is 7U133-190. wondering if there is a compatible hose that i could pick up at autozone, orielly, ect...
TheKurgan
Florida Keys
Tough call. That's a tight fit so you'll probably just have to do some measuring. If the hose doesn't touch the supercharger, you can probably get away without the hard line. However if the hose touches the supercharger, those fins on the back are likely to eat through the hose. You might be able to find some kind of flexible coolant hose. Alot of people have had to reclock that housing too.
