Correct fuel pressure regulator?
Hollowdweller
Fixing to order a fuel pressure regulator, this one has the correct -an fittings for the line I’m planning to run but I don’t know about “fuel pressure range”? Says it’s 40-75…is that what I need?
07 Boss
Sin City
In stock configuration, fuel rail pressure is dependent on manifold pressure (or vacuum). I believe it is manifold pressure plus 39 psi or something like that.
07 Boss
Sin City
And you didn't give us much to go on. What exactly are you doing? Makes a difference. You gonna run boost? Is it still a returnless system? A lot of variables.
Hollowdweller
lol…sorry! I have another thread going about my build “Roush build” so I just assumed everyone would know…my bad! Yes I’ll be running an On3 76mm kit, e85, On3 fuel hat running 3 320 pumps, return style thinking 8an supply & 6an return (6 or 8 to rails?)hoping for 650rwhp.
There’s this regulator for about $70 less that LMR has too but it’s only 6an inlet/outlet. Guess I still see the advantage to running 8 supply then going to 6an inlet….but every time I got tuned on previous cars I always ran into fuel issues (could’ve been bad tuner)!
Hollowdweller
I’m hoping to only have to run 2 pumps at a time. I’m installing switches and relays to each pump to turn them on/off independently. Only cost $85 more with what I already have so why not I guesd
