Whiskey11
SCCA Autoscrosser #23 STU
- Joined
- Feb 24, 2012
- Posts
- 1,644
- Reaction score
- 2
I don't know about the commonly agreed upon convention but I can tell you this. A torque arm is lightyears better than an upper control arm. It is not even close. Using the Watts link, TA and adjustable lower control arms gives the rear end a tremendous ability to articulate. You just have to drive it and you will see. Also you will have to change the lower control arms because the axle does move a tiny bit back and you need the adjustability to compensate.
Why would the axle move rearward with the torque arm? That sounds to me like the TA itself is too long and needs to be shortened. I'm also not sure how a set of LCA's fixes that since the TA itself would be keeping the diff at the same length regardless of the LCA length, then you shorten the LCA's?! Seems like that would pull the ends in while keeping the rear out. It would certainly be worth a call to Cortex to clarify on the issue.
I'm well aware of the "it's recommended" clause, but it simply isn't possible with my class. I could retrofit some poly bushings in on one end and have some custom Delrin inserts made for the axle end that would allow articulation, but that'd be EXPENSIVE and still doesn't allow for any adjustment, if indeed it was necessary.
I might have to wait and see what MM comes up with for their TA and pray it is bolt as well. Exhaust modifications are fine, it's just welding (personal reasons) and attaching to subframe connectors (not really an issue on the S197 chassis) that are no-no's.
