TurboX
Formally Buzz Lightyear
"Add both these numbers, divide by 2 and this is your intake centerline. In my case, 156.5 + 81.5= 238/2= 119. I want to set my intake centerline at 114 degrees, this means I need to retard the cams 4 degrees. I am not going to show how to do this because depending on what you use to degree the process will be different"
i see one mistake here if you got 119° and your cam intake centerline is 114° you need to ADVANCE the cam not retard it...
nice write up
I needed to take it back 4 degrees, to me that is retard. I will look at wheel this weekend to make sure
