No peppers. Shredded cheese does not a nacho make. Has to be nacho cheese.
Nachos rule.
There you go again! Hahaha
Nachos sooth the savage beast SD.
Nachos rule.
I think we should test this theory! And data log the temps at part throttle and so on. I know a guy that has one I will see if he is down to do it. And I will adjust his tune so that it will pull timing for the inlet temps. Just so we don't blow it up! I'm not saying I don't believe you, I just want to see how hot it really gets.There seems to still be some confusion as to the intercooled/non-intercooled thing...
It's as simple as this... If you shut the pump off on an intercooled roots/twin screw, you WILL damage your motor in a short amount of time. That is a fact. The intercooler buried in the center of the motor will soak up all the heat from the supercharger, the engine and it will hold it in and increase your charge temps to well over 200 degrees at part throttle and WOT (on a tune setup for 85 degree intake temps, and 120 degree charge temps).
On a kit without an intercooler the air coming right out of the supercharger goes right into the cylinder heads without being additionally heated by the dormant intercooler.
There is a difference. You can't just disconnect your intercooler pump and say it's just like a non-intercooled kit.
Not taking sides here, just stating facts.
if that is infact the reason are u going to write an apology since you felt the need to vomit all over this forum
A non operational intercooler under a twin screw would in fact be like a toaster.
can someone explain to me what a "defective" piston ring looks like?? 20yrs in the business and ive never seen one
Ok, well after reading Brenspeeds post, this is simply a major whipple install fail. Essentially completely fucked the most critical parts of it, the bypass and the intercooler.
