From the Torsen website...
"The TORSEN T2-R takes the T-2's performance to the next level. By combining the patented Equvex gearing from the TORSEN T-2 with
friction enhancing plates, the T-2R allows improved mobility an traction under the most extreme conditions."
Seems like a "clutch" and "friction enhancing plate" are essentially the same thing.
Additionally, here is a diagram from the same page on the Torsen website
In that picture, I see a part labeled "multi plate clutches" and another "preload springs." So it would seem the T-2R does in fact use a preloaded clutch system exactly as I described.
Agreed 110%. A locker or a limited slip are the best choices for the strip. Torsen differentials are terrible for hard launches.
