Does Water Wetter improve intercooler efectiveness?
aleborjas
Maracaibo, Venezuela
those of you that use trunk mounted tank what water pump you use? i bought the tank from chiseled performance the tank is beautifull i order it with a rule 1500 pump and that pump is a complete crap the water moves tooooo slow now the iat's are worst than the tank in the front with the stock bosh pump, i will try cobra jet water pump (55 GPH) to see...
94tbird
4R70W FTMFW
NY/NJ
you need a rule 2000 pump if you want an in tank submerged pump. mine moves the fluid FAST. for external you need a meziere pump. forget about the lightning (FRPP) pump
94tbird
4R70W FTMFW
NY/NJ
also if your voltage to said pump isnt enough it will pump slower
