Door lock problem
Fikok
Switzerland
hi guys
I know this problem has probably been mentionned but cant find a solution
my driver door wont unlock with the remote neither with the unlock button inside, it lock with the remote and both driver/passenger button
passenger door work just fine.
i tried both remote, i tried replace the door lock actuator but its the same...
any idea ? thank you a lot !!
redfirepearlgt
hi guys
nope no clicking sound at all, unlock work but no lock
Which is it? won't unlock or wont lock????? Makes a difference. Take the time to inquire clearly rather than in chatter text.
Lee Hendrickson
Al
hi guys
Had the exact same problem you describe. I could lock both doors with the remote and with the inside door lock/unlock switch, but only unlock the driver's door with the key or the inside door handle. It is not a wiring or actuator problem as it is locking. Mine ended up being a bad SJB which had corrosion from a water leak. Pull your SJB, open it up and check for corrosion. If corroded, you'll probably need a new one. I bought a used one from e-bay for $100.
