Did the same. Driver side about to crap out again. Still on the hunt for a set of the non-insert panels.
i did this about 2 weeks ago using the 3m spray adhesive that i use to put carpet on speaker boxes and so far it still looks great. i didnt scrape the foam off though. i used the air compressor and lightly blew off any loose foam particles leaving 95% of the foam still on the panel. im gonna add yellow piping today then i'll post up some pics.
You did not say whether you applied adhesive to both the panel and the leather. Most contact cements require a coat on both surfaces to be bonded. When I did my drivers side, I applied two coats of adhesive to both the panel and the leather, then used my wifes pastry roller to roll it from the bottom up, worked like a champ, no issues. Hope this helps.Shit didn't work. Removed the backing and put one thick layer of contact cement down. Waited 20 minutes and put another good layer down. 20 minutes later I reattached the leather using a towel from the middle out. Let is sit overnight in my house. The leather is mostly bubbled and will probably fall off again within the next month.
Later,
http://www.ebay.com/itm/360391130953?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
i believe they have other colors
in the quanity box i put 5 and it gave me about 2 1/2 left over.
