Driveshaft loop question
Joe combs
Northern Kentucky
After doing my auto to stick conversion I went to install my BMR Driveshaft loop only to find out that the rear O2 sensors on the BBK catted x-pipe (long tube headers) hit on the loop bracing arm. So my question is this, what is everyone using for a driveshaft loop on their cars, that have this setup???
07 Boss
Sin City
Don't know how much room or how it is hitting the arm but these might help. Otherwise I would just buy a some new bungs and have them welded in where the sensors will fit better.
Laga
Chicago
I may just have to modify the arm that comes up to the loop, but that's how it goes when building these cars
I don’t have your setup, but that’s what I had to do with mine. A little bending and a little trimming, and it eventually fit.
Curtis B
Calgary
When I upgraded my exhaust with BBK long tube headers and catted X pipe, I could not put back the BMR safety loop because of the curve in the support tube, between the bracket and the loop. I am thinking this winter, I will lock the bracket and loop in a jig, cut off the curved tube and replace it with a straight piece of angle iron which should clear everything. Challenge will be getting all the right measurements. If nothing else it will be good welding practice.
