DTC po174-171 vacum leak?
gils maui pony
since I've installed the sct tuner, in stock mode, the computer threw me a po194-191 [too lean] and bogs now and then up to 3k's.....
I talked with Matt at BAMA this morning and he suggested to check the hose from the throttle body to the intake.....I DONT SEE A VAC HOSE from there to there!..I'm I blind?
could it be that in stock mode, running 92 octane can do this?...
for the bog issue Matt is suppose to send me another file....
Much Mahalos.
Gil
ZeroSVT
Whos watching?
Jasper, AL
Yes he does, Its common that the hose coupler from the intake tube to the throttle body can get crimped up into the throttle body by the clamp.
Um if u have a cai and are returning to the stock tune u r going to have problems. Thats why most cai's require a tuner.
ZeroSVT
Whos watching?
Jasper, AL
Just a few thoughts, I have seen people over tighten the Cold air intake at the throttle body to much, causing the tube to create a opening to let in to much air under the TB. Look under the throttle body where the cold air intake meet and look for a large gap.
Most common problem
