Dyno with Mutha Thumpas
Kalatrax
Albuquerque, NM
Finally dynoed my car. Made terrible numbers. I finally got the dyno graph emailed to me and it's looking very weird. If you notice there is a drop at about 3300 RPM's, it is also very up and down throughout the pulls. He did cut it at 6400 because as you can see it's running lean. This is a Bama tune....is this all in the tune?
nasty281
MODIFIED STANG
memphis
I had pretty identical mods as you except I had hotrods and made 340 before install of my 4.10s. I think the tune is the only culprit here imo
GOTTORQ
Connecticut
From what I read, Bama runs a bit conservative on there tunes. Supposedly brenspeeds are a bit more aggressive. I am currently running a Bama tune with the mods in my sig. Made just over 320/320
go302
Tits McGee
Oklahoma City
Interested to see the numbers after a legit tune. I had mutha thumprs as well and only made 325/325 with longtubes, jlt 110 intake, and delete plates. The afr was like 10.8 on a BAMA tune so I always wondered what hp I would be at with a nice dyno tune.
Franchi
Senior JR Member....
In a house, with a mouse
I was at 335 rwhp with mutha thumps, deletes, pullies, l/t to o/r h and catback, and C@L intake and that was on a brenspeed dyno tune on 06 GT so about in the same ballpark as rest.
Main difference I saw between tuners, ( Bama, Brenspeed and Lund ) was driveability of each.
fdjizm
Drag Queen
NY/NJ
What afr was it? hard to tell by the graph.
Looks like 13 or so, which is not incredibly lean, in my logs it looks like bama targets 12.6-12.7 for afr.
Kalatrax
Albuquerque, NM
Can you read the plugs? is their sniffer calibrated?
The plugs have less than 10k miles. It was dynoed at Motiva Performance here, I'm sure it was calibrated correctly. They actually have one of nicest dyno setups I have seen. Two new in ground dyno's.
Any idea on timing? I had a bbr tune that was lean as fuck but it pulled hard as shit!!!
No idea, I haven't datalogged it myself seeing as it's going to get tuned next week. From what I have seen mod motors don't like running lean at all, I am almost wondering if it didn't pull timing top end because of it being so lean.
BruceH
BBB Big Bore Boss 322
Dyno jet?? Who here has run on a Mustang Dyno with numbers??
Hemilol ran 300/300 with hot rods and a bama tune. Not sure if he had long tubes or not at the time. This was on a Mustang that was calibrated to simulate a dynojet during a dyno day gathering.
702GT
S197 Fanatic
Las Vegas
These cams have a habit of being rough to tune. My tuner did a lot of work with cam angle in the lower rpm because spark/fuel wasn't producing the results. My current mods yield me 360/320 with the mutha thumprs. The lower rpms (3500 on down) need a good bit of detailed tuning to get right. The LSA on these cam's make them very fussy if not rev'd high.
Kalatrax
Albuquerque, NM
We will see what Chris can squeeze out of it on Monday. Do these cams work well with your nitrous setup?
702GT
S197 Fanatic
Las Vegas
No N/A cam works well with nitrous by nature lol. N/A cams with tight LSA's breathe for high rpm powerbands, and unfortunately you lose nitrous out the exhaust just like you would boost if you were FI. However I have to say they work quite well with nitrous in my opinion. Sadly I never finished my nitrous system before I got a deal on a D1 kit, so I never got to spray on the new setup. Been very tempted to go down the dark path again, but I think the procharger will be better for the motor than what I had in mind with nitrous lol.
With these cams, fear not and spray more. Most if it will go out the exhaust anyway! Makes for awesome fireballs between shifts lol.
