E 85? Coyote
deepimpact
waco tx
I'm thinking of swapping the 47lbs and go with id725 or id1000.2013gt stage 1 vmp kit put down 573 rwhp with vmp tune. My main question is what injectors will go e85 I know the id's will just wonder if there are other options,and if there will be anything else I need besides injectors to run e85.
deepimpact
waco tx
Just got back with vmp he said id1000 and boost a pump will do it damn 1000 bucks for them shits haha oh well makes more power.
Unless maybe I can run just some ford racing 80lb and boost a pump idk I don't want to cut to many corners if it is safer to run the others
wbt
ID1K and BAP will do but personally if I were to go power adder with e85, I would spend the extra and get a return style fuel system and never look back.
deepimpact
waco tx
What pulley are you running?
Sorry just got back to this been busy as hell it's the 85mm pulley pushing about 9psi rev limit is set at 6800 tho cause the 47lbs I'd like to spin it on up to 7300 7400 to see what it pulls on the dyno
9 psi? why bother with the corn?
go 15-20##!!
