chad05gt
First a little background. Motor has forged rods and pistons, 9.5 cr, FRPP 62mm tb, PMAS HPX maf, 80 lb injectors, GT500 fuel pumps, and Comp 127300 cams. Supercharged by a Whipple 2.3 with a 3.5" pulley and Innovators West 10% od balancer.
The baseline comparison is 531/460 rwhp/tq. on 92 pump gas with this pulley. I had originally planned to use a 3.250 pulley that made 553/492 on pump gas but ran out of fuel pump at about 5700 rpms.
The final tune has 21 degrees of timing. I called it quits at this point because the motor is making more hp than I had ever planned for and even with my crappy driving should put me into rollcage territory. My previous best of 11.68 was with the motor making 515.
Here's the end result. We could only pull to 6400 due to fueling. 575/505. This is a gain of 44/45 hp/tq.
Will you post numbers after upgrade fuel pumps/inj.?
