Do you do all of your own re-valving/rebuilds in house?
Have you ever disassembled the R2’s?
Today, no. In the past, yes.
I did not disassemble them. But I have examined the interior of the R2.
I agree, for most people it would be. Car better than the driver and all that.I think that the $1000 packages from Sam are more than sufficient.
Please don’t take this the wrong way. I understand you probably don’t have a complete understanding of the differences between a single and twin tube damper and how those translate into “performance”.I think that the $1000 packages from Sam are......better solution than a low end coilover. $.02
Your statement comparing the two types of dampers is wrong in so many ways I couldn’t begin to list them all. You are talking about two completely different solutions (designs/technology) when comparing the two. Comparing the two is like comparing a 302 Windsor to a 302 Coyote motor. You can throw the entire “catalog” at the Windsor and it still won’t be a run of the mill Coyote motor. The Coyote has too many core design and technology advantages for the Windsor to overcome.
I’ll take a average single tube over a top shelf twin tube damper every time.
You keep saying it isn’t a good damper. Anyone can make the same claim about anything. Why are they not good dampers? Specifics please..... the R2, which is not a good shock,
I keep hearing cheap, cheap, cheap from you but what does that translate into? Are these cheap components leading to failures? Are these cheap components hurting performance? Or does cheap just mean less expensive. Please explain.coupled with cheap components,
How much is “slightly”sells for $2150.... Better quality shocks with better quality components sell for slightly more than that.
Why are components from China or South America automatically bad? Made in the USA doesn’t automatically translate into better quality. Every country has its share of “junk”. That includes the USA. 20 years ago people used to say “Japanese junk” all the time. Now they are known for having some of the best stuff on earth.Why spend that money on the R2 with it's Chinese and South American made components
....and bad design.....
The R2's are EASY to rebuild/re-valve........that can be rebuilt and revalved...
Are you saying that the Vorshlag CC plates are included in the price of the AST's? If not that’s irrelevant isn’t it? They are an extra cost then???and the camber plates can be reconfigured to match any future suspension purchase?
What is the best choice then? Pricing?But if the budget allows a $2000+ suspension, the R2 is not the best choice.
I'd rather have a well built Windsor than a Chinese knockoff of a Coyote.![]()
We can agree to disagree.I'd rather have a Koni Yellow on decent springs than a chinese monotube.
Oooh, not me. Vavling is more important than mono v. twin. And I know all the perks of a mono... runs cooler, damps small movements (less than 1/4") better, etc. The thing is, we aren't running Indycar or F1 cars. We have a lot of suspension movement, so much so that nitpicking over over 4mm of travel is kind of silly. Especially since an average mono-tube has iffy damping. Perfect example: Bilstein vs. Koni STR.T... I sell both, have run both. Find the Koni STR.T to work every bit as well as the Bilstein's. The damping control is every bit as good for much less money. And that's not an average monotube, and comparing to something less than a Koni Sport.
The thing that is being left out is with the whole koni SRT-T's vs Bilstein HD's is that the Bilstein HD's can effectively dampen double the spring rate than a Koni can. But using your "strong bar, lighter springs" style the koni str-t's work out for the bang for buck champ.
I know this is not the norm. But how something is valved out of the box doesn’t concern me (as long as it’s serviceable of course). I can do all of my own valving. It would take me less time to valve the car than R&R the struts/shocks and do an alignment.
That being said so far I’m more than happy with the valving in the R2’s as delivered. Now that I am running more spring rate and the car will have “slicks” on it the next time I go to the track maybe I will need to address the valving. Time will tell.
To be fair then we are no longer talking about your "average" monotube, right?
You are falling for the whole "self adjusting" claim. In a Bilstein you have a damper that is non-adjustable, yet supposedly can deal with all these different spring rates. Is it magic????
Gmitch can you do a build thread on your car? I'd like to see what you choose and why.
The best advice I can give you is DON'T! LOL!The reason I ask is id like to eventually do a track car myself
Are these the Koni’s you are referring too:
Koni STR.T
http://www.stranoparts.com/partdetails.php?PartID=483&CategoryID=64&ModelID=5
I’ve driven a S197 with those teamed up with Steeda Sports and it took me all of 2 laps to over-drive what they could dampen. In short they were slowing me down.
Everything in my life is a compromise. I'm used to it.
Sam - Read closer, i didnt say Koni Sports. Here is the story: I got kw clubsports and the dampers are shot ...at least 2 of them for sure(rears). So I figure I would take off the rear KW's and slap a replacement on there while I got my others rebuilt. I called and talked to both koni and Bilstein. Bilstein HD's were rated to handle upto 500 in/lb spring. I've always been curious about both Bilstein and koni. I really wanted to try koni sports but that "experiment" was getting pricey. I WAS initially gonna use the Koni STR-T's, but after talking to Koni, they said they were way out of range for a 340 in/lb spring. Way out. They recommended the sports. So the manufacturers are where I got my information. And I double-tapped info on the bilsteins via Maximum Motorsports. As far as shock dynos, I'll have my kw cs' dyno'd by Penske unless AST decides to take interest for free. If that is the case, they can dyno the Bilstein's too.
I spend a lot of time reading in this section, but not much posting. I’m here to learn.
But after reading your posts lately I would like to make some comments.
Selling and having “The Best” sounds like a great way to go. Who wouldn’t want to? You’re missing something though. What are the 99% of us who can’t afford “The Best” to do? Just leave our cars stock?
And frankly your posts lead me to believe that unless I have a pocket full of money, don’t bother giving you a call. The vast majority of the Mustang crowd can hardly imagine spending $2000 on coilovers, let alone $3000, $4000, $5000, $6000……… And according to you all you can get for $2000 is “Chinese Junk”.
It seems like you have a pretty cool shop there, do neat builds and you sell a lot of high end stuff. Should I feel inferior because I can’t throw money around like you and your customers can? Because that is the tone I get from your posts.
I’d rather deal with someone who understand the average Joe like Sam Strano. He won’t make me feel like I’m not good enough because I have a budget.
And as a parting gift, a word to the wise. I’ve spent a lot of years in sales, I’ve run large sales teams, done lots of advanced sales training and sold everything from industrial equipment to motorsports products. And one very important thing that my time in sales has taught me is that you NEVER disparage the product/item/service you are selling against. You instead sell the advantages/benefits/etc of yours. When all you do is rip apart the “competition” you torpedo your own credibility and run the very real risk of loosing the sale because no one wants to sit there an listen to negativity piled on negativity.
You are selling some nice products. You should have no problem selling them on their benefits opposed to your perceived shortcomings of what you are selling against.
Good luck
Hold on now.. there is way too much going on and some confusion is setting in.
*I* never said STR.T's were my personal preference, I agree you can overrun the damping of them if you drive really hard. Which is why for track guys, or guys that just like to drive hard I recommend Koni Sports... STR.T damping is about like a Sport *at full soft*. I have no doubt that in that instance the D-specs are "better" because they have more oomph in comparison, and by comparison Koni Sports are also better for the same reason (and I think superior if for no other reason than they don't link compression and rebound together).
I was comparing STR.T's and Bilstein's, that's all. I wasn't comparing STR.T's and D-spec, or Sports, or R2's...... I'm not sure that was clear. Both STR.T and Sports are Koni's so it could be when someone says I'll run a Koni that they mean Sport and someone else takes it to mean any Koni like a STR.T.
Koni makes no bones about what the STR.T's mission is. It's there to fight for the less than premium non-adjustable market... Tokico Blue kind of territory. And that's how I use it. For those looking for a damper with good street valving that make the car feel secure and give confidence, and a lifetime warranty. And fwiw, if it took you two laps to overdrive them notice it didn't take you one... and I'd never recommend those as a first choice for a car I know was going to be a track car.
... Maybe it's because I work with sales people all day, but I don't read any sales pitch in his posts. I see info, yes, which may help sway someone towards or away from certain products, but a direct sales pitch, no.
I for one am very happy to have as many people here that are as capable at driving these cars as we have. I hope to one day join them in people who can make these pigs turn.
