Eibach pro kit lowering springs installed, passenger rear side sits 7/8" higher than driver side.
07 Boss
Sin City
It is actually a proven fact that they should e facing a specific direction. Even Eibachs directions talk about spring orientation. I personally have experienced this issue myself.
Eibach instructions talks about the the up and down orientation of the springs. The rear springs are coiled differently on the top and bottom and the instructions tell you to have the logo being right side up to make sure the tighter wound coils are up top. Rear shock perches are flat and have no relief for the pigtail of the coil. Ride height will not change no matter which way you orient the spring. Front springs are different because the the pigtail has to sit properly in the perch to acheive the proper ride height.
86GT351
Sunny South Florida
AI Overview
Learn more
Correct Way To Install Coil Springs | TCCoA Forums
On a Mustang, the rear coil springs should be installed with the "pigtail" (the small loop at the end of the spring) pointing towards the driver's side of the car; this means both rear springs will have their pigtails oriented in the same direction, towards the driver side, ensuring proper alignment and function.
Key points about Mustang rear coil spring orientation:
  • Pigtail direction: The pigtail should always face the driver's side on both rear springs.
07 Boss
Sin City
AI Overview
Learn more
Installed/swapped springs at least a dozen times, twice with eibach and I've never seen that in their instructions or any other brands I have installed. I have never oriented my rear springs. I can guarantee you though that clocking the springs will have zero effect on ride height.
Autokyrios
VA, USA
Sorry, my brain was latched onto my current coils which are flat. I don't have my stock rear seats anymore, but I don't recall the seats being shaped. Either way, I do have one of the old springs and the coil seems nowhere near thick enough to cause that kind of deviation if the end wasn't sitting right. Little, maybe, but this is nearly an inch, right? I'd be more inclined to think the coil orientation has more to do with compression characteristic than idle height.
I'm still with swapping them left to right and seeing if there's a change. Or throwing the stock springs back in and seeing if it goes back to normal.
DARINLYNE
Canada
Recently had Eibach pro kit lowering springs and Bilstein b6 struts and shocks installed. Replaced Eibach sportline springs. The rear passenger side sits 7/8" higher than rear driver side. Dealership has had it back twice. Said it needed to settle. 2500 miles later they say install is good, must be the springs.
Does anyone know or have any information why this might be happening?
My next move is to put my old Eibach sportline springs back on. The ride is fine, the height is OK except for the rear passenger side.
The car doesn't handle as well as it did with the sportlines. It did scrape in certain situations, but for better performance I can avoid certain areas and be careful. Anyone else have this issue?
I have same issue with 2011 I just bought it has the Eibach pro kit and only rubs on passenger side. Still trying to find fix.
DieHarder
Sans nothing bent the easiest fix is coil overs. Work great but expensive. Of course that still means you're still compensating for something.
brasil
Germany
back in 1995 I ve had a SN95 5.0 Conv. put some Eibach springs in... And the Story began.. The car came deeper and deeper. ( not kiddin ! ) At the end of the story, I moved back to the OEM Springs.. because the car was far too close to the street..too low.
Same with my 2010 that I own right now.. 45mm H&R springs installed when I bought the car. Went back to OEM .. much better for a DD ( in my opinion )
