SoundGuyDave
This Space For Rent
- Joined
- Apr 9, 2007
- Posts
- 1,978
- Reaction score
- 29
Okay guys, I’ve got problems; electrical issues that I’m just not able to track down.
Setup: After my wreck last year, I’ve slowly been fixing the car up as time and funding allow, and am now down to trying to fix the electrical issues, without much more to do before putting it back on track.
The car is a 2006 tub, with stock dash, SJB, PDB and front light harnesses, but with an FR500S chassis harness, 2008 MT engine harness (I think), and a 2008 PCM. The car starts, runs, idles decently, and is a monster at WOT, but is an absolute mess in between. Tune is custom from Modular Depot, and is most likely NOT the issue. At idle and at part throttle, the A/F ratio wanders cyclically from around 11.0 to 15.7, but datalogging reveals that the computer is NOT commanding the mixture change. Under load, the engine loads up and stumbles badly, and some test tunes with locked (huge) amounts of extra fuel do nothing to alleviate the symptoms.
Doing some double-checking for verification purposes, I was checking the pinout on the engine harness, and connector C175E (bottom on the PCM) looks like a 2008 harness, but has no Ford part number on it, just a tag/bar code that reads “K05”, back near the IMRC motor control plug.
Issue two: The one time I had it out on track post-wreck, I had a cooling issue, which may or may not be relevant. Under high load, I was able to get two hard laps at Road America prior to having to pit in to cool the car down. This was with the radiator completely unboxed (no side or top deflectors), so that may be the main cause, but if I shifted at 6K up into fifth (GOD that ratio sucks!), I could keep the temps manageable.
I’m about at my wit’s end with this, and I’m hoping that somebody might be able to come up with an idea or two of what’s going on. Honestly, it sounds like a bad ground in one of the sensor loops, but I went over all the ground connections and they all appear to be clean, tight, and low-resistance.
HELP!!!
HELP!!!
