jodadejss06gt
TEAM DELETE SHIT
OK well compare the slip from the same day, faster 60 more speed than the slower 10. Then slower 10 back to the 11. Doesn't make sense to me?
man.....what I'd give for a DA like that.
Well boys I'm back at it again.
Changes:
Built motor(11:1), 76mm turbo, still e-85, T56 magnum with McLeoud RST, and still he 17" ET streets. Only change i've made to the suspension is adding Rear Sway Bar Relocation in prep for 15's and tightened my the sway to its tightest setting. Stock UCA, UCA mount, and no LCA drops.
My first pass last night was [email protected]. I cut a 1.882 60' leaving at 4800 on the 2 step @ 18psi in the tires.
Next pass I ended up spinning a hair on the line with a 1.9 and a 11.2@134.
3rd pass 1.899 and [email protected].
I kept upping the 2 step but it wouldn't come out any better. Then the 4th pass came and I was racing a friend. I ended up cutting a 0.089 light and my best 60 of 1.824, but when I WOT shifted to 2nd the smoke poured from my clutch. I was still able to drive it but the engagement was almost at the top of the pedal.
Anyways long story short.....2.66:1 for my 1st gear coupled with a 3.55 rear gear do not leave happy clutches or good 60' times. The car was like a snail out of the hole and then WAAAAAAAAAAAAA.
Alternator crapped out on my way home and I had to get AAA to tow me the rest of the way.
