pieperz06
i need to get blown
well i have been installing my new clutch and flywheel and i ran in to a brick wall.
i have a a fidanza 96-04 alu flyweel 6 bolt (lethal performance said it would work with my mcleod rst)
here is my question i got the stock flywheel off and went to put on the new one and it wouldent line up and so i was like WTF is going on.
we took it off and put it next to the stock one and sure enough the bolt holes do not line up. it is not off by much maby 1/8 of an inch on like 2 of the holes. it is actual even less than that but there is no way it would fit
after this i got out some calipers and measured the stock one and the bolt holes were all equally spaced and when i measured the fidanza 2 of the bolts are not the same spacing apart.
does this sound like a manufacturing mess up or is it suppose be this way
