MrAwesome987
I'm sure they would. You can get them pretty cheap from rock auto/summit/ebay
Hi GriffX,I have seen some cars with heatshields on top of the hydro bushings. My 07 doesn't have some, is it worth to add them?
Yes....the FP units are OEM GT500 (SVT) units which have the stiffer durometer rubber & stouter, low friction ball joints vs the OEM units for V6, GT & are designed to accept the heatshields.Thanks!
I will try to find some. The hydros have lots of superficial tiny cracks, I have some FP arms already bought. I guess the FP bushings are a bit firmer than the normal.
Would be great,thanksHave a set that should be arriving today or tomorrow and can get you dimensions
The overall box with both control arms is 22"x16"x11" (LxWxD) and weighs 34 pounds. Each arm is separately boxed inside the overall box and those smaller boxes are 21.5"x15.5"x5". You could stack them as shown in the below pic and they will fit into the same individual box. Hope this helps with your packing ideas.
