Front Strut Diminsions
Low Dogg
North of Frederick,MD.
I would like to know the front strut deminsions. I need to know lower sturt mount, hole size and center to center diminsions. Would also like to know width diminsion, where spindle slides into strut. Iam sure somebody has a stock set they took off, in there garage. Thanks for any help.
hamish
B.C.
I measured hole size=14.25 mm /.56 in
center to center =99.75 mm / 3.93 in
width =20 mm / .788 in
I used digital caliper, hope this helps
Low Dogg
Hey thanks for the help. You dont know the shaft diameter, where it goes into the caster/camber plate. Thanks for the help.
