FRPP P Spring Rates
cm581978
NJ
Ive searched, without much luck. Does anyone know what the spring rates are of the P springs?
csamsh
OKC
170 front, 120 rear? I think that's about right.
kcbrown
Vorshlag tested the spring rates for the P springs. Here's the results:
Seems a bit low to me. I'm presuming that Ford Racing hasn't changed the springs for that kit, and that there isn't a different version for later S197 cars than for earlier ones.
With those rates, I'd think you'd be on the bump stops all the time.
sheizasosay
Alive
The car weight is gonna collapse a coil or more. The working range probably starts at the 1.5" range in the chart which is typical 200ish in/lbs.
kcbrown
For those specific springs, at 1.5", the rates are 147 lb/in for the front and 109 lb/in for the rear.
Considering the Boss 302 springs are 148 lb/in for the front and 186 lb/in for the rear, and that's for a ride height that is half an inch higher in the front and at least an inch higher in the rear, the P spring rates seem low, especially for the rear, which doesn't seem to change its rate until 3.5".
The rear P springs don't ever reach even the rate of the base GT (156 lb/in).
A car with P springs might not, while cornering hard, be riding on the stops in the front, but I don't see how it wouldn't ride on the stops in the rear...
sheizasosay
Alive
I read it wrong. You guys got the rate right.
cm581978
NJ
Good info! Reason I ask is I have K springs on my car, but I have P springs in a box. Was going to order some Konis this weekend and am looking for a less teeth chattering ride. the streets here in NJ arent exactly in the best condition. I believe the K springs are closer to a spring rate of 225 or so in the fronts.
csamsh
OKC
I think the low spring rate is probably a good thing. Switching from theory mode to experimental here for a second...the Shelby GT and its P Springs was the unquestioned master of SCCA F Stock until the coyote existed.
frank s
at Play
Paradise
I thought the Shelby Mustang GT had the "K" springs.
Any road, the "P" springs on my '09 GT/CS never hit the bump stops either in careful road driving, or on autocross (Bridgestone Re-01s) or Chuckwalla Valley Raceway (Goodyear F1 Supercars). Koni yellow struts/shocks.
cm581978
NJ
Yes, the Shelby GT does come with the K springs. Id have to believe the P springs, with a lessor spring rate are more ride compliant
sheizasosay
Alive
I wish I would have bought a Shelby GT instead of my Roush Sport. Just having the 6 speed would have been worth it. I like the styling better too for that matter.
69Mach1-409
South Jersey
Shelby GT was a regular GT with a CAI, axleback, some suspension, and tune. They had the stock GT powertrain.
Whiskey11
SCCA Autoscrosser #23 STU
You left out the "And it's a real Shelby" from the list of changes! ;) That does matter to some people. FWIW, the Shelby GT is still a strong contender for F-Street R and F-Street. I'd venture to guess that it's the better F-Street car but the half inch of wheel width deficit to the Brembo stangs is a buzz kill.
sheizasosay
Alive
I couldn't believe it when you typed it. I been sitting here googling to verify. I must have just ran into a rash of modders that dropped 6 speeds in and I called it the norm. Hell I was even gonna buy one and it had a 6 speed, but it was wrecked. Well I feel better about the Roush now ;).
BMR Tech
Traction Vendor
Tampa, FL
It would help if we knew the free height of the springs.
Anyone have these springs laying around, that can measure how tall the spring is - as it sits on the floor?
Until I know those heights, I won't try to guess the effective rates of these springs.
BMR Tech
Traction Vendor
Tampa, FL
Actually, I'm going to guess and say the "rate" that people are looking for, with these springs, is around 180F / 140R.
cm581978
NJ
Sounds about right, as I believe the K springs are 225F/190R or so. I'm assuming there has to be a noticeable right difference between those rates.
