Goose
2007 GT/CS
For the rebuild of my car, I have decided to go a different route and I will be selling my STS single turbo kit. Below are all the items included:
- 60mm T4/T3 Turbo
- All the piping, couplers, and clamps included with the kit
- Intercooler
- 39lb injectors
- Predator MAFia
- Dual exhaust side which is the dump for the wastegate (thermal wrapped).
- Custom made tips which look much nicer then the small tips that come from STS.
- Boost gauge
- Custom made Y pipe that flows much better then plugging one side of your H pipe, which is the way STS has you do it.
- Modified cat back pipe to provide better ground clearance. This is the pipe that goes from the H pipe to the turbo.
The only additional items you would need are the following:
- Blow of valve
- Wastegate
- Hand held tuner
- Oil pump (I would recommend a turbowerx oil pump)
I am asking $2,450 (plus shipping) for all the items included above, which is $2,500 less them what a new kit goes for from STS. Not to mention that with the STS kits you wouldn't be getting the custom modifications that were done to improve the performance of the kit, and a boost gauge.
Depending on how much power you want to make, you would also have to get either a Boost A Pump, or a GT500 dual fuel pump system. The car is currently at a local shop and is in the process of having all the parts removed, so they should be available soon for anyone that might need it asap.
Thanks,
Carlos
- 60mm T4/T3 Turbo
- Intercooler
- 39lb injectors
- Predator MAFia
- Boost gauge
- Blow of valve
- Wastegate
- Hand held tuner
Thanks,
Carlos
