FS: GT500 Pumps and Lines
Redfire
I have a modified GT500 pump assembly for sale. The hat has a connector that has been modified to plug right into the factory harness. You will not need a second FPDM. I ran this setup on gas for a year and E85 for a year. It supported over 700rwhp in both applications with a single BAP.
Included will be 2 6an lines out of the hat to the y-block, a 8AN line to the rails that has a 90 degree 8an fitting for the fuel rails. You will need an 8an fuel filter as I kept that for my current fuel system. The filter was in the 8an line from the y-block to the rails.
I will also include some extra blue aeroquip hose. The hat can be quite difficult to get in and out and it got sliced a little. As you can see from the picture I only have three of the rubber stops for the base of the pump. I am sure the last one is in my tank somewhere but couldn't find it. I used the rubber flapper in the 6th picture that is missing on my new hat. You will need to transfer that over from your old hat.
I don't like to sell modded parts as their can be problems with a failure with one of the modifications but this setup will work good for someone needing more fuel.
The price is 300.00 shipped as is to the lower 48 UPS ground.
