michael.konor
Got my #80 injectors cleaned, serviced, and flowed last week. Got them back from a reputable shop and reinstalled them into the car. Car started and ran just fine afterwards.
Flash forward 3 days...
I get into the car and hit the key... "THUNK". Car won't turn over beyond the thunk and stop. Have a spare battery, no change. Installed a spare starter, no change. So I start digging deeper, especially since I'm about to install my new high speed Zimmer's Hotside Turbo setup, as well as installing new camshaft chain parts while I'm at it.
After the thunk, I know I've got a problem mechanically, so I pull off one of my hotside pipes and fuel POURS out of the car. I keep going and my engine is full of fuel.
I've attached two pictures. One is when I pulled off the vac hose off the back of the intake and fuel poured out, and the other is the fuel pouring out of the intake after I pulled the intake off.
After pulling off the intake, I removed all the spark plugs and cranked the engine. Well, you guessed it... looked like a 4.6l version of old faithful geysering out of my engine. What a mess on that first cycle. Stuffed rags all over the engine and cranked it until the fuel stopped coming out.
Of course, I didn't have a problem with the injectors doing this before the servicing. So, it's something they did or didn't do.
But what could it be? Is there some reversing valve inside the injectors that could have been reversed? What's holding them open full time that even when the car is off it's siphoning into the intake?
