D_bone33
Ok, so i started my car and it sounded really rough and then died. Tried to start it and of course it wouldnt run. I then checked every fuse associated with the fuel pump. Checked everything to see if i wasnt getting either fuel, air, or spark. I then pinpointed it to fuel. So then checked the pump, it had no fuel in the return line on the top of the pump. So then checked the module in the back. The plug had a burn mark somewhat on the left two, which is the fule pump module power and something else. Well i replaced the plug(thanks to a gt500 fuel pump harness i had). So i made a whole new plug. Well then put it back into my old module and the car ran. Then it did the same thing a few more times. I was able to get it running agian and again, and then it died and wouldnt run. Then i had my old gt500 extra module they send you with the pump. I removed the old factory module and put the new gt500 module on there. Well, went to start my car today and it was idleing good and i got in it to leave and it ran out of gas. Popped the trunk and loked at it. It is doing the same thing, plug is burnt up and the connector is pretty shot. I have one more module plug connector i can use, but if i mess this connector up i am out of luck. I just wanted to see if anyone knew anything else to check out. I am figuring it is somewhere on the harness possibly a wire burnt through and it is causeing it to arc or something. The fuel pump in the car is a stock gt pump with a piggy back pump on it. l am maybe thinking that its putting too much strain on the stock harness that was designed to run 1 pump, and now is running two pumps and its bogging down...anybody have any ideas?
