JesseW.
car-vortech with water intercooler and lt headers. I bought it this way 3 years ago.
i was performing the fuel pump TSB for the 05-06 cars because i was having the car bog badly at autocross and when less than 1/4 tank and noted the fuel pump was built in 05. It ran great otherwise
To my surprise when i pulled the pump it DID NOT have the walbro 255 hanging off the side of it as is in the vortech directions and there is no BAP. took the pump out of the hanger and it is the stock 155 lph pump. the filter on the pump had a lot of stuff on it and the metal screen was half blocked by what looked like chunks of rubber.
anyway, the 1/4 tank and bog at autocross has went away since changing it, but i feel that i may be at or over the limit of the stock pump. what is the max power the stock pump will support?
I've outran several I/E/tuned 5.0's and C5 Z06's and have dyno sheets from the previous owner of 440whp. doesn't seem to be starving for fuel... should i upgrade the pump and if i do, will i need to go get it tuned? i am very happy with the way it runs now.
