Fun at Atco 8-26-12
808muscle
Maui
Well if my motor goes after "thousands" of runs I will open a Corona and toast its departure. That was a well built strong motor to last that long. Good luck with the rebuild.
dysan
Dis-Member
Williamstown, N.J.
Stuck a scope down and from the looks of it, it seems like a valve may have dropped. Won't know till I get up the desire to start tearing into it. I'm starting to wonder if the bronze guides I have started to fail after I put my cams in since I began spinning it 500-600 rpms higher than before. Guess when the time comes, steel guides will be used.
Here's a quick picture I took of the scope screen.....
dysan
Dis-Member
Williamstown, N.J.
Well everyone...went from bad to worse. I used my friend's scope to look into my blower and I see scraping on the rotors and walls of the blower so that may be junk too. Looks like it was all caused by a broken follower on an intake valve that much have pushed the valve too far down and caused major piston to valve contact.
I will start taking stuff apart over the long weekend.
Looks like there may be another big block build on here. I'm thinking mid 500 cube range, transfer my fuel injection system and ECU over and run it on E85. Lito believes he knows how we can do it so it may be pretty trick. Will be quite a while until I can do it though since that won't be cheap either.
Now to figure out how the hell to bolt my 4R70W to it!
As I told you earlier James, very sorry to read this.
dysan
Dis-Member
Williamstown, N.J.
Thanks guys...I was somewhat looking forward to pulling stuff this weekend but not now. Has to be done either way.
