Fuse and fuse box help.
Daddycreswell
Long story short....PO of my son's 09 GT had installed a system at one point. Instead of running the amp on wire to proper location they ran it into the fuse box, the HVAC blower/Wiper motor. The problem is the combination of the wire and fuse has made the clips that hold the fuse in to expand to the point that the fuse just falls out. Short term fix right now is toothpick broke off in with the fuse. I can't see the clips to clamp them together. Anyone have any ideas of how to fix this? Thanks
Sent from my SM-N960U using Tapatalk
08MustangDude
Resident Fuktard
Disconnect the battery, and press each side towards the middle with a small screwdriver.
Daddycreswell
I can't see the tabs in order to get a hold of them. I guess I'm going have to remove the whole fuse block.
