Gear change help - not install... Parts choice 2011+
-rpark-
Im still trying to round up all the parts I need for a gear change for a 2012 GT with manual transmission.
I'm using Amsoil MTL in the transmission and Amsoil 5W-20 Signature series in the engine, so I figured i would use their gear oil also. I have three choices:
Amsoil Severe Gear 75W-90
http://www.amsoil.com/storefront/svg.aspx
Amsoil Severe Gear 75W-110
http://www.amsoil.com/storefront/svt.aspx
Amsoil Severe Gear 75W-140
http://www.amsoil.com/storefront/svo.aspx
I know Ford calls for the 75W-140, but is this the best weight to use?
And with the Amsoil, do I need to use the friction modifier?
http://www.summitracing.com/parts/FMS-M-19546-A1/
I definitely want to go with the Ford Racing install kit. This is where I'm a little confused on what part I need.
One guy recommended this kit:
http://www.summitracing.com/parts/FMS-M-4210-B/
This kit says it's designed for IRS axles, which I dont have.
Then there is this kit:
http://www.summitracing.com/parts/FMS-M-4210-C/
This kit is for Non-IRS cars, but for 1986-2004 models.
Those two were the only ones I've been able to find and neither seem right.
Also, I guess on the newer models, it is best to add the updated ring gear pinion bearing???
http://www.americanmuscle.com/88-gear-assembly-2010.html
For gears, I want to use the Ford Racing 3.73's or 4.10's. I'm still having trouble deciding.
3.73's
http://www.summitracing.com/parts/FMS-M-4209-88373/
4.10's
http://www.summitracing.com/parts/FMS-M-4209-88410/
And last but not least, I want to put on the Ford Racing rear differential cover:
http://www.americanmuscle.com/frpp-88-diff-cover.html
With the above cover, I'm sure oil capacity will increase. So how much oil do I need to buy total?
I would really appreciate it if someone could help me out on what all I need to get because I would like to get this stuff ordered next week.
Thanks in advance,
Rob
dalemllns
SLOMOD
Arab AL
most 8.8's hold 2.3 qts with stock cover so get 3 to cover it. Use the non irs install kit. But if you have low mileage all you really need is a new pinion, gear, pinion bearing and some shims, as the other bearings are still in good shape and need nothing. Lastly 75 140 is all i have ever run and I wouldn't recommend changing it IMO
BadHabit2Break
Houston, TX
Have you looked at Late Model Restoration?
I got my whole kit (Gears and install) for $249. I believe they give a member discount also.
-rpark-
Yes, but they use a generic install kit instead of the Ford Racing install kit, and also give you Royal Purple oil in the incorrect weight.
I would like to buy the Ford Racing install kit, but can't seem to find out exactly what part number I need. I wish somebody put a kit together with all top quality parts.
