Glass Water Spots
Mystickeith50
South Jersey
Guys I have these horrible quarter window Louvers I've always wanted off. Two questions....how is the easiest way to get them off and I assume the glass underneath is heavily water spotted. How do you clean the glass? Clay?
Johnf78
Upstate NY
The factory ones are just on with Velcro. They just pull off and you can remove the Velcro with a razor.
nbk13nw
If it is not too bad then you can take 0000 steel wool and window cleaner. If bad then glass polish and a drill adapter for a good polishing pad or a DA and proper pads.
Redline727
"I wanna go fast!"
RVA
Vinegar should remove the water spots then wax the glass.
Sent using Tapatalk
LAStang1234
----------DSL----------
Little Rock
I used some sturdy fishing line and some goo-gone? to get mine off. Glass was actually in great shape when I took them off.
Bullitt 3309
San Antonio, Texas
If vinegar doesn't get the spots off, try CarPro Spotless. I would not do the steel wool thing unless your are ready to polish the glass using a proper glass polish like ceriglas...
Mystickeith50
South Jersey
Well that sucked. Those water spots said fuck you to the vinegar or clay. I ended up needing the Porter Cable and an orange pad. That was brutal.
