Glowshift oil filter sandwhich billet adaptor 05+
This just came off my car around 2 years old. Glowshift billet oil filter adaptor has 4 1/8 npt ports. Installs between the oil fitler and the block, I used it run the oil feed to my turbo and and oil pressure sender for a gauge.
Comes with 3 plugs and the one open port with a 90 degree elbow installed. This fits the stock oil filter thread style 22mm X 1.5.
$20 shipped
http://www.glowshiftdirect.com/oil-filter-sender-adapter-22mm.aspx
HellsBells
620/677
SoCal
Were you able to fit the FL820 filter (the one for our car) with the sandwich plate? If so I'm interested!
calispecial08
Dang, wish I would have had this so I wouldn't have had to tap the pan
Thanks Ray, never tried it with sway in stock location. Makdaddy's turbo setup has the front swaybar relocation plates that moves the swaybar down a few inches so should be good.
