Sam Strano
- Joined
- Oct 23, 2009
- Posts
- 918
- Reaction score
- 6
Let me see if I can clear this up for you guys.....
1. Koni Sports is a generic terms that applies to any Koni "yellow". If you modify it to work on a car, does that make it a Koni Sport for an S197 Mustang? I don't think so, because it implies that it's the Koni Sport that Koni makes for the car. If it's a Sport insert that's been worked to work in the car--that's a different beast than claiming it's that particular shock for the car from Koni. And at that point, you aren't dealing with Koni spec anymore you are dealing with what that company determines for valving.
I know it might see like splitting hairs, but it's not as we are talking about two different parts completely.
2. Camaro had Koni's, my springs (I make springs for those cars) and my swaybars installed on it, plus the tire change. Without the tire change the car was 3.4 seconds a lap faster. I'm not directly comparing the cars though they both weigh the same and are both rwd V-8 powered. Only showing your results aren't magic considering the tire change, etc on a course of that length. That's all.
3. Fair enough.
4. I can't be everywhere, if you have specific questions, then you need to contact me directly.
5. Yes, they are all underneath the tower.
3. Fair enough.
