GT 6R80 Transmission P07AA
Flintbeker
Germany
Hey guys,
I have a 2012 Mustang GT with a 6R80 transmission. After making noises and jerking under full load for about a year, the transmission has finally given up. Error code P07AA, limp mode, and it's hardly shifting (very late shifts with the engine revving high).
Being from Germany, getting it repaired isn't straightforward and is estimated to cost around $5000 USD. Now, I'm wondering about the differences between 6R80 transmissions. I can get a used 6R80 from a 3.7L Mustang for about $1800 USD. Alternatively, is there a good place in the USA to buy a Stage 1 6R80? Import costs are around $500 USD, and I'm contemplating if it makes sense to upgrade to something better right away.
Thanks for your help!
JEWC_Motorsports
S197 Junkie
The 3.7 transmission is different and will not work. If you have any mechanical ability you can repair it yourself.
windowirk
UK
I could really use that manual too, but the link above doesn't seem to lead to the right place. PDF is the preferred format since my computer only supports that one. Another electronic format is fine as well. In that case, I'll try converting it using the DWG to PDF Converter https://pdfguru.com/dwg-to-pdf which I usually use to add notes to such PDF manuals. That's actually a pretty useful feature besides just converting. Maybe someone else will find it helpful too.
