Gt500 injectors with Kenne Bell
07BLACKStang
Austin, TX
Will gt500 injectors work with a Kenne Bell 2.6L? I have the gt500 fuel rails too. Just trying to figure out if I can use these or if I need to sell them and get some EV6 injectors.
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Shorter is ok, as there is a roughly 1/2" spacer that is typically used under the stock fuel rail to raise it up high enough, but that is also for the 39# injector lengths.
I would think, if the diameter of the bottom end is right, and the connector is right, being 1/2" shorter would fit.
Anyone using them would provide a better answer, though.
FAST3V
Austin, TX
S&H has spacers as well. I have the EV14 injectors on my setup and will be able to keep these injectors when I go TT bc I'll have the spacers. :) Ask Jeremy or Bobby about them.
TexasBlownV8
Central Texas
I guess I'm thinking, if the b kit is already using spacers to accommodate the taller injectors, using a 10mm shorter injector should be no problem.
Bring the injectors and fuel rail out, Brandon, and we can take a look.
07BLACKStang
Austin, TX
ok, Mike. I will get with you on a good time to bring them over. Would be nice if they work. I emailed KB but have not heard back. I will probably try and call them tomorrow if I have time.
